Полная версия этой страницы: Флуд, флуд ,флуд.
Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544, 545, 546, 547, 548, 549, 550, 551, 552, 553, 554, 555, 556, 557, 558, 559, 560, 561, 562, 563, 564, 565, 566, 567, 568, 569, 570, 571, 572, 573
http://auto.mail.ru/article.html?id=44647фиат как всегда сплоховал.
а хто у нас в сварке разбирается?
можно ли газопровод, ну по дому например -трубы. варить эл.сваркой-например инвертором. а не газовой горелкой?
хто в этом шарит smile3.gif ?
а почему бы и нет? Не вижу (и не знаю) никаких ограничений на сей счет
да не раньше просто баллоны тягали, когда газ варили, теперь видать все эра горелки кончилась, пришла эра инвертора..вот ток че то взрывов в домах больше стало, може просто больше новостей просто получаем...а раньше умалчивали.
Взрывы это печально...но при чем тут сварка? опрессуй готовый газопровод, стыки пеной обмыль.
да не просто тут после какого то закона, всем в добровольно принудительном порядке ставят за счет государства счетчики на газ.
врезку и вварку делают с помощью инвертора....
помню когда предкам отдельную воздушку на 4эт. кидали, котел ставили -все только с горелками работы проводили, хотя инверторы в то время уж были, но все одно баллоны тягали.
Ну вот например, раньше много лет назад, если требовалось заварить трубу (стояк) всегда слесаря тащили на этаж шланги для ацетиленовой горелки через лестничный пролёт в квартиру. И так и варили. Просто были и сварочники обычные трансформаторные, но вель эта надо затащить ещё на этаж, подключиться к щитку на лестничной клетке, а там поводка выдержит или нет.... Так что проще, удобнее было использовать газосварку.
А сейчас да, инверторы - простота, доступность. Жрёт меньше, КПД выше, нежели обычный сварочный транс. У меня в гараже, пробовали инвертором варить, даже лампы не мигали. С обычным трансформатором, такой номер не прокатил бы.
да то что инвертор не садит лампыэт и ежу у меня на даче понятно. я за сам металл-шов надежность прочность - - -одним словом качество интересуюсь.
ведь можно проварить металл, а можно и "на срать" однородного шва не будет, ну тип раковинки и т.д. ....
вот че интересно.
вот че интересно.
о че за фича двойное сообщение бъет
А тут уж, от сварщика зависит. Опытный буквально чувствует процесс варки.
ну то то так просто работы выполняли "молодежЪ" может они профи в этом-я ж не в курсе.
но вот чего на инверторы прешли и как отразится на качестве-интересно стало.
хотя у них спросил, работают на контору "горгаз" то бишь не левак-контора, и говорят уж два года варят на инверторах.
Нормально значит, поверь. Они ведь инвертор используют чтобы варить чуть проще было. Сам прцесс варки тот же остаёться.
Наши совковые требования к газопроводам иначе как необоснованно завышенными и не назовешь-всё на сварке должно быть!
Представляете, как я удивился, увидев за границей сборку газопроводов на всяческих скрутках...в наидоступнейших местах!
о молодцы-все свинтили...
вот че интересно.
вот че интересно.
Сам постираешь или как??Редактни его. Ты ж автор.
Цитата(Timon07-j @ 9.12.2013, 16:09) *
былиб у нас такие тачки в гаи - яб с мустанга не слазил вообще)))))
такие бы машины не дошли до гаража,какую чиновник дернет,какую начальник гаи и все машины рассосутся
Timon07-j
уж и помечтать нельзя.
щас кстати наткнулся в соцсетях на фото нового мустанга. вот это херня у них получилась
лансёр, не?))))
лансер х - ужасная машина.
я про внешность. 9-я вообще соска. а уж эвик так вообще
Если мустанг,то только такой
Timon07-j
ребят. если не сложно - проголосуйте пожалуйста. http://vpenze.ru/concurs/view/17 за Каролину Мартынову.
не в моих правилах постить подобные объявы, но хочется сделать ребенку приятное
Timon07-j
и вот Вам для развлекалова.
увидел впервые в "что? где? когда?" на музыкальной паузе. и вроде в Кремле на концерте исполняли, но не смотрел)
+1
Olezha73
90 пацаны! ))) http://youtu.be/0X8E4EGlSi4
Цитата(Lyzhenkov @ 11.12.2013, 1:52) *
если русский (с)
Karev
Ребята, у нас пошли ужасные морозы днем -25...
Скажите пожалуйста если я куплю электрический котел подогрева, что нужно еще будет докупать? Так как собираюсь подключать к 220 и чтоб круглые сутки стоял)
проголосуйте
+1, на работу приеду еще голосов сделаю
+1 сделали.
а не посчитают там за "атаку и накрутку то" а то у соперников чего то совсем жиденько.
Цитата(1300SL @ 11.12.2013, 6:46) *
+1 сделали.
а не посчитают там...
Не посчитают, остальные родители скоро проснуться и будет гонка))
Мы уже как то всем клубом голосовали, гонка была емаема, по моему в позапрошлом году.
Тем более они сейчас хитро сделали - голосовалка через соц сеть.
от меня два голоса есть, завтра еще попробуем.
BIG DEN
Тоже +1. Что интересно, самыми активными почитателями жительницы Пензы являются "ребята со всей Украины" friends.gif
+ 5 за Каролину, можем, делаем.)))
VAZ-74
Ребят подскажите как установить железные решетки вентиляции , перепробывал пару вариантов не получается пистонов родных теперь тоже не найти.
Timon07-j
спасибо всем ребят! надеюсь до 21 продержимся. щас вторые. там за пацана одного нехило впряглись)))
VAZ-74 , подбирать пистоны , у нас на рынке есть целый отдел , так там горы разных пистонов клипс и т. д к иномаркам и нашим авто.
ritchi
+еще 1
+1 Каролина.
Timon07-j
ну не хотите про Украину - как хотите))
вот вам скрин интересненький. все против законов физики
каких законов? Намекни хоть на раздел)
Timon07-j
любых. колея спереди шошика сделана самим шошиком)))) сзади виднеется еще одна. ушла по крышу, но выехала
P.S. движок просто рассчитан на модель поведения авто не меньше уазика (вплоть до маза тягача). а тут легковушек напихали сверху))))
Цитата(Ekvalayzer @ 11.12.2013, 19:22) *
буду тут тогда постить....
Ненадо.
ктати возил россиянина из города донецк. гоняют сюда мазды на ТО по гарантии. типа дешевле чем в ростов-на=дону. и по деньгам также....
типа 2500грн. за 2,5часа с заменой всех расходников у нас тут , а в россеи около 15000рублев надо отвалить...
так шо на украине усе дешевше, и жизнь-жисть. тоже.
Что то темнят ростовчане. Я тоже хотел ТО в Крыму сделать...а по деньгам то же самое выходит..никакой экономии(
VAZ-74
Уже поставил ,закрепил на пистоны для обивки двери.
Olezha73
RedLinE09 в том то и дело,что нихрена не расточен ;) и у Травникова спрашивал,он сказал что пойдет,для городской езды.будет экономный.поганать конечно не получится без расточки
спросил у него за жики,но пока нет ответа
получил сегодня посылочку
и присмотрел уже баночку
думаю что пойдет такой выхлоп
Timon07-j
ладно-ладно)))))
Knjaz
А где заказывал выпускной коллектор и почём ?
Я заметил, ты и впускной где-то нашёл?
